okay guys so heres the story.i needed new rings in my shee. while the motor was apart i threw some new pistons in there too. (nothing wrong with them just thought id throw some new ones in) i needed a a new clutch cover so i put a new one in. now my motor starts fine runs fine. but its making a clicking noise like something is in the motor. but i assured nothing is in my motor. i put new springs for the exhaust to make sure the exhaust wasnt leaking any air. i think my clutch is bad is it possible that the clutch is the problem not letting the gears move freely?! also the exhaust are different temps? help any please
Are the pistons in right??? Did you possibaly break a reed petal, or a piston skirt. Did you take flywhell of for anyreason. Is pickup hitting flywheel. Possibilities are endless man. Check your tranny oil for metal flakes.
