scav8er Posted June 4, 2010 Report Posted June 4, 2010 Ok so i tore into my bottom end for the first time. Put everything back together rode down the street twice and everything ran great now when i kick the kick starter i hear metal to metal clicking or clanking in the bottom end. Any ideas? Quote
midlifecrisis Posted June 5, 2010 Report Posted June 5, 2010 Ok so i tore into my bottom end for the first time. Put everything back together rode down the street twice and everything ran great now when i kick the kick starter i hear metal to metal clicking or clanking in the bottom end. Any ideas? not sure if the noise is coming from when you kick it, or when its running, but I do knoiw from personal experience that the kicker bushing , and the crank bolt have given me issues in the past, causing weird symptoms and sounds. Quote
camatv Posted June 5, 2010 Report Posted June 5, 2010 did you use blue locktight on EVERY bolt nut on the inside of the motor? you better pull the cover off and see what fell apart.. Quote
KickStartMyHeart Posted June 5, 2010 Report Posted June 5, 2010 did you use blue locktight on EVERY bolt nut on the inside of the motor? you better pull the cover off and see what fell apart.. A-MEN!! Quote
scav8er Posted June 6, 2010 Author Report Posted June 6, 2010 (edited) Well started to pull everything apart tonight and I found the problem. I took the stator cover off and the flywheel nut fell out! Put it back on with locktight! Started right up and no rattle! Oh well live and learn at least it was something cheap this time Edited June 6, 2010 by scav8er Quote
