I have a 87 that is almost stock and the clutch has started to slip, will a $50 ebay kit work good? and can i do it through the cover or do i have to take the whole side pannel off? Or is it possible to adjust it, It has been slipping for a couple days now.
Chances are, the clutch is toasted, if it's been slipping for several days. You'll have to remove the whole side cover to change the clutch, and you'll need a new clutch cover gasket. What brand is the eGay clutch?
does your perch have some free play to it? if there is no free play then you prollly just need adjustment. make sure you can pull in on the lever a half inch or so before you feel resistance. tusk is a pretty good clutch i wouldnt hesitate to run one unless its a higher power motor
What oil are u running? I have always used tusk HD kits in all my bikes. Right now I just run three stock springs and three hd springs. Make sure u soak the clutches over night before install
Its ams oil 4 cycle oil. says its good for wet clutches
make sure you read your Clymers on how to adjust the clutch before putting on the cover. If you dont you will have to take the cover off again and adjust it. if you are new to working on banshee's, nitronate has a good video for working on shee's.
vitos sells a clutch that works great for 69 bucks
i would say check the oil. if it started slipping are the oil change then that might be the cause. should have used ATF. some oils have friction modifiers in them and they are not good for a clutch.
he used the amsoil 4 stroke oil for wet clutches should be ok, I've used that with no problem
