I have the stock rear end, the Urethane round slider, located on the swing arm pivot, keeps wearing off.
the roller on the frame are fine, is there a bearing supposed to be under the slider?
Edited by Jimmi
i had this problem once. your going to want to make sure that you put a small washer on both ends of the roller that way the bolt doesnt hold everything tight. the washer cant be too big though.
