F.T.W. Banshee Posted May 17, 2010 Report Share Posted May 17, 2010 What kinda paint are you guys useing for your cylinders? Quote Link to comment Share on other sites More sharing options...
camatv Posted May 18, 2010 Report Share Posted May 18, 2010 get um polished.. VHT engine paint works good if not.. get anything on them it takes it off like gas, oil, pee be carefull Quote Link to comment Share on other sites More sharing options...
bansheesandrider Posted May 18, 2010 Report Share Posted May 18, 2010 PJ1 make a case and cylinder paint, it is available a larger MC shops. Quote Link to comment Share on other sites More sharing options...
F.T.W. Banshee Posted May 19, 2010 Author Report Share Posted May 19, 2010 I was thinking powder coating the cylinders. Any body know around how much that would cost? Quote Link to comment Share on other sites More sharing options...
F.T.W. Banshee Posted May 20, 2010 Author Report Share Posted May 20, 2010 I talk to my local powder coater and he said that powder coat work on the cylinders cause they get to hot. I was wondering if this was true cause i see alot of banshees with custom colors on there jugs. Quote Link to comment Share on other sites More sharing options...
F.T.W. Banshee Posted May 23, 2010 Author Report Share Posted May 23, 2010 BUMP Quote Link to comment Share on other sites More sharing options...
firebanshee Posted May 24, 2010 Report Share Posted May 24, 2010 BUMP I just used high temp engine paint,but i run alky so my cylinder does not get near as hot as a gas motor. Quote Link to comment Share on other sites More sharing options...
odaen Posted May 24, 2010 Report Share Posted May 24, 2010 I talk to my local powder coater and he said that powder coat work on the cylinders cause they get to hot. I was wondering if this was true cause i see alot of banshees with custom colors on there jugs. Many people powdercoat their cylinders. I've had a set of cubs powdercoated. Never had a problem. Quote Link to comment Share on other sites More sharing options...
NitroTate Posted May 25, 2010 Report Share Posted May 25, 2010 Powder holds up perfectly fine. PM me if you want them done and I'll get you a quote. Tate Quote Link to comment Share on other sites More sharing options...
