djackbanshee Posted May 16, 2010 Report Posted May 16, 2010 For sale banshee triple cases , crank , head , 34mm vm carbs , Triple ignition with cdi and coils . Crank has to be assembled . New rods and bearings would be ideal. There is 1000$ of labour just to make the cases ( you can check with many builders ) This engine is not for the beginer , looking for a serious buyer . Capable of 150hp on stock cylinders. Asking 2000$ Thank you Quote
djackbanshee Posted May 17, 2010 Author Report Posted May 17, 2010 CYLINDERS OR LOCKUP COVER NOT INCLUDED. Thank you Quote
dragbanshee98 Posted May 18, 2010 Report Posted May 18, 2010 some more info on the setup? what sort of cylinders are these made to fit? your description leaves alot to question, no offense.. Quote
DUMBASS Posted May 18, 2010 Report Posted May 18, 2010 some more info on the setup? what sort of cylinders are these made to fit? your description leaves alot to question, no offense.. ...if u look ...its got stock cyls on it. so im ASSUMING thats what its made to fit Quote
djackbanshee Posted May 18, 2010 Author Report Posted May 18, 2010 It will fit any cylinders with a stock type bolt patern . Either 3 stock cylinders , a triple cub..... . will fit a triple cheetah but you will have to get the cheetah head.. I would love to have it running but i already have enough of one fast bike and looking to buy a hot rod. So it will eventually have to go. Looking for serious buyers. Quote
djackbanshee Posted May 20, 2010 Author Report Posted May 20, 2010 Any questions just ask !!!!!! Quote
pabansheematt Posted May 20, 2010 Report Posted May 20, 2010 Thats an intresting looking motor. Quote
djackbanshee Posted May 22, 2010 Author Report Posted May 22, 2010 Would make a sick engine for the dunes. Is capable of 150 hp the way it is now . Make me an offer Quote
djackbanshee Posted May 24, 2010 Author Report Posted May 24, 2010 I would sell only cases and ingnition for 1500 $ Then you can drop in your lets says 10 mill crank and cheetah cylinders and have a 200 hp 800+cc engine for cheap Quote
