bp12 Posted May 9, 2010 Report Posted May 9, 2010 well heres the skinny i need to knows where to set idle screws after tors removal any help will be appreciated thanks fellas Quote
SD1026 Posted May 9, 2010 Report Posted May 9, 2010 (edited) set as in where to install them???? but if you installed them already turn them in until you see the slide start to move then back it out half turn. that should be your starting point. Edited May 9, 2010 by SD1026 Quote
bp12 Posted May 9, 2010 Author Report Posted May 9, 2010 set as in where to install them???? but if you installed them already turn them in until you see the slide start to move then back it out half turn. that should be your starting point. yes, where to install them? Quote
SD1026 Posted May 9, 2010 Report Posted May 9, 2010 yes, where to install them? you have to drill and tap the hole yourself. im sure you can find step by step on the computer or you tube. Quote
SAVAGE420 Posted May 10, 2010 Report Posted May 10, 2010 yes, where to install them? Here man *** http://www.toomey.com/html/ik_install.htm *** Quote
bp12 Posted May 10, 2010 Author Report Posted May 10, 2010 Here man *** http://www.toomey.com/html/ik_install.htm *** thanks sav Quote
