thebrittishguy Posted May 8, 2010 Report Posted May 8, 2010 i have a spare banshee motor that i have never used since i bought it second hand (think its a RZ because it has an oil pump below the water impeller?) anyhow. split the cases, with help from Savage420 (thank you!) and i found this..... how does this happen and do i need a whole new gearbox or can i get just the replacement gears? thanks for your replies Quote
SD1026 Posted May 8, 2010 Report Posted May 8, 2010 Its a lot to take apart a tranny you can get a good one from a part out for cheaper. Quote
SAVAGE420 Posted May 8, 2010 Report Posted May 8, 2010 Its a lot to take apart a tranny you can get a good one from a part out for cheaper. It's not that hard to take the gears off and replace what ever ones you want too change. Thats also an RZ trans, and there not plentiful as the banshee trans. So it might be hard to find them ratios he would need. So Tiaan, just sell it all to me . Drum forks and gears...lol thanx Quote
cbn70 Posted May 8, 2010 Report Posted May 8, 2010 Just figure out which gears you need and take them off the cluster. Then go down to the dealership and order new ones. Then put them on the shaft and you are good to go Quote
Larry's Shee Posted May 8, 2010 Report Posted May 8, 2010 (edited) Which gear is that ? BTW, pretty fubared !! Edited May 8, 2010 by Larry's Shee Quote
tonyown Posted May 9, 2010 Report Posted May 9, 2010 look at my 6th gear... happened like 2 years ago... riding in snow with paddle, 2 on the shee it's hard on 6th gear lol Quote
