jon321 Posted April 26, 2010 Report Share Posted April 26, 2010 Well I decided to rejet the quad and took out the 320"s and replaced them with 340"s,anyway after I put the 340"s in i noticed my idle was very high from when I had the 320"s in there, so i checked all the little hoses,the boots on the carbs and did a soapy spray test to see if there was any air leaks . So upon closer inspection of the 320"s that were in there this is what I found the one on the left is a 320 with a countersink and the one on the right is a 320 RD normal . I was starting think that the carbs were dialed in for these jets and when i put in those 340"s it may of set the idle off a bit. I dont know why someone put two differenly machined jets in there , but they are the same numbers though, What do you guys think the story behind these jets are?Carbs are Mikuni 34mm Quote Link to comment Share on other sites More sharing options...
Larry's Shee Posted April 26, 2010 Report Share Posted April 26, 2010 The CSI in me says that you have two jets made at two different times or on two different machines. Funtionally the same because flow is determined by the size of hole in the jet . Quote Link to comment Share on other sites More sharing options...
shawn941 Posted April 27, 2010 Report Share Posted April 27, 2010 The CSI in me says that you have two jets made at two different times or on two different machines. Funtionally the same because flow is determined by the size of hole in the jet . x2 Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted April 28, 2010 Report Share Posted April 28, 2010 When RD jets come into my shop, they go straight in the trash can. "NO RD JETS ALLOWED!" Quote Link to comment Share on other sites More sharing options...
SAVAGE420 Posted April 28, 2010 Report Share Posted April 28, 2010 name='jon321' date='27 April 2010 - 11:47 PM' timestamp='1272437241' post='1123885'] When RD jets come into my shop, they go straight in the trash can. "NO RD JETS ALLOWED!" [/quote What are RD jets anyway? Really Dumb Jets Quote Link to comment Share on other sites More sharing options...
Snopczynski Posted April 28, 2010 Report Share Posted April 28, 2010 name='jon321' date='27 April 2010 - 11:47 PM' timestamp='1272437241' post='1123885'] Really Dumb Jets Quote Link to comment Share on other sites More sharing options...
AKheathen Posted May 3, 2010 Report Share Posted May 3, 2010 hahaha, well, i'm willing to bet you pulled or bumped something, like a float, or just didn't get the cable seated all the way back in. check the sync first...... and, a side note- mikuni jet size denotes flow, which includes taper, as well as oriface size...not that it really matters, here Quote Link to comment Share on other sites More sharing options...
jon321 Posted May 4, 2010 Author Report Share Posted May 4, 2010 hahaha, well, i'm willing to bet you pulled or bumped something, like a float, or just didn't get the cable seated all the way back in. check the sync first...... and, a side note- mikuni jet size denotes flow, which includes taper, as well as oriface size...not that it really matters, here Hey everyone my quads running like a top,so problem resolved Quote Link to comment Share on other sites More sharing options...
Erwin8r Posted May 6, 2010 Report Share Posted May 6, 2010 Hey everyone my quads running like a top,so problem resolved So... what was the issue? Enquiring minds want to know! Quote Link to comment Share on other sites More sharing options...
jon321 Posted May 11, 2010 Author Report Share Posted May 11, 2010 So... what was the issue? Enquiring minds want to know! I must of somehow bump the idle screws on the carb when replacing the jets , its running great now ,i synced both carbs Quote Link to comment Share on other sites More sharing options...
