i stripped one of the clutch spring bolts the otherday putting my motor back together and i figured i may as well buy an aftermarket clutch basket. i tried using the search function with no luck so my question is what would be the best aftermarket clutch basket? i noticed that i have to reuse the stock gear how hard is that to do? is there any other parts i need besides for the basket, inner hub and pressure plate? and what are the bennefits of an aftermarket basket?
if you stripped out one of the clutch spring bolt holes, then you stripped out the inner clutch hub, not the basket. New clutch hub is like 30 bucks from jeff at fast i believe.
