I just rejetted my banshee and put aftermarket pipes and silencers on it as well (FMF Fattys with Power Core 2 Silencers) Main jets are 290 and pilots are at 30. It started right up however it is putting out quite a bit of smoke. It wont idle and just shuts down when you let off the throttle. I did ride it around the yard and it just had no power at all. Even when I kicked it once it made a real loud pop. So what do you all think is wrong? Im new to the banshee world and trying to learn but this has me baffled.
First off I know I am supposed to turn the air screw out 1 and a half turns. I believe I have done this. Is this the screw located on the TORS boxes on top of the carbs? Or are they located directly on the side of the carbs? What are the big screws on the TORS boxes? If you need any other info to help diagnose please let me know and I will post what I can......thanks!!!!
try syncing your carbs.. making sure the slides more at exactly the same time.. that will make ur bike run like crap... with the tors the screws on top
sets the height of the slides
**Update** The bike has plenty of power on top end. ALOT of power. No sputtering on 1/2 throttle+. When starting out it idles rough and wont idle at all, you have to keep on the throttle to maintain idle. Also in low throttle you can hear popping from muffler. It is like single pops not puttering.
My wife's first Banshee had Fattys and Cascade silencers with a Toomey 2 into 1 K&N style filter. I had 290 mains, 27.5 pilot needle clip in the middle position and the air screw, which is on the side of the carb, was at about 1,75 turns. This made it start easy, it was the wife's bike and she did not complain, and run great with good power all the way across the range.
The screw on the TORS is your idel adjustment. The air screw is the screw located on the side of the carb.
