dmfisher71 Posted April 16, 2010 Report Posted April 16, 2010 ok i am new to the banshee i just pickep up a motor to put in my frame just got it out of the shipping box and was kinda playin with it a bit it has stock carbs with tors removed still has the throttle cable on it i was pulling it open while watching the slides the left side carb is opening quit a way before the right side opens. i would guess that these need to open at the same time and speed. am i right or should one open before the other??? any answers will help thanks. Quote
formula1 Posted April 16, 2010 Report Posted April 16, 2010 ok i am new to the banshee i just pickep up a motor to put in my frame just got it out of the shipping box and was kinda playin with it a bit it has stock carbs with tors removed still has the throttle cable on it i was pulling it open while watching the slides the left side carb is opening quit a way before the right side opens. i would guess that these need to open at the same time and speed. am i right or should one open before the other??? any answers will help thanks. Yes they need to be synced to open at the same time. You can play with the adjustments to make them go up at the same time. Quote
