hillshooter421 Posted April 15, 2010 Report Posted April 15, 2010 I have a 10mm cheetah with 39's and when i hit the throttle and it revs back down i get some fuel that comes out of the overflow. Has anyone had this happen and how is it fixed. Do you think it may be the fuel level to high or is it from the vibration when its reving down? Quote
Bruce_Blaine Posted April 19, 2010 Report Posted April 19, 2010 I don't know much about it, but I had the same problem and someone told me my float was sticking. Just a thought. Quote
mailman Posted April 20, 2010 Report Posted April 20, 2010 (edited) It is normal. Don't worry about it. The motor shaking back and forth on a banshee causes this. Your motor vibration is worse with the "big cheetah" also. Since the carbs are not centered on the motor, (due to the fact that there are 2), amplifies this effect. If your motor only had one carb then it would be centered and would not shake as bad. I hope that makes sense. Mailman Edited April 20, 2010 by mailman Quote
hillshooter421 Posted April 20, 2010 Author Report Posted April 20, 2010 It is normal. Don't worry about it. The motor shaking back and forth on a banshee causes this. Your motor vibration is worse with the "big cheetah" also. Since the carbs are not centered on the motor, (due to the fact that there are 2), amplifies this effect. If your motor only had one carb then it would be centered and would not shake as bad. I hope that makes sense. Mailman Is there any way to correct it? Quote
