fastquad02blaster Posted April 5, 2010 Report Posted April 5, 2010 Im not a pro but it sounds like your motor was built to run high octane and by using 87 octane, you made it detonate from the first bang. Im guessing it was detonatin so bad that the fuel was becoming unstable long before TDC and pre-ignighting the fuel, meaning when it was time for the spark to normally ignight it, you had no fuel or very little left to burn. You would have slowly been chipping away at your pistons, causing them to leak and lower your compression and crank case pressure, also causing power to drop fast. And BINGO was his namo Quote
bayou banshee Posted April 6, 2010 Author Report Posted April 6, 2010 i also think it is a stock piston, is it even possible to build a motor to run 110 with a stock piston? thanks guys ya'll are helpin me alot!!!!!!!! Quote
bayou banshee Posted April 6, 2010 Author Report Posted April 6, 2010 i know three was oil in the gas, i mixed it myself. 4oz a gallon Quote
mopar1rules Posted April 6, 2010 Report Posted April 6, 2010 i also think it is a stock piston, is it even possible to build a motor to run 110 with a stock piston? thanks guys ya'll are helpin me alot!!!!!!!! sure you can build a shee motor to run 110 octane on stock pistons. get some smaller domes or shave the crap outta the head. LOL. Quote
