Well to start off I have 15/41 gearing right now and I like it how it is. My chain is real worn out and so are the sprockets. I have been looking around and there a few different sprockets and chains. What are some good solid sprockets to use? Also how about a chain would you go x ring, o ring or what? Should I just order the same amount of links for the new chain or how do you do that I have never put a chain on. Thanks alot
SuperSprox front sprocket. Dont run a $10 dollar crappy front sprocket. The front sprocket is what takes the most abuse. Buy a good one.
http://www.rockymountainatvmc.com/productDetail.do?&navType=type&webTypeId=124&navTitle=Drive&webCatId=9&prodFamilyId=23006
Steel Primary Drive rear sprocket. You dont want an aluminum rear sprocket they wear out fast.
http://www.rockymountainatvmc.com/productDetail.do?&navType=type&webTypeId=124&navTitle=Drive&webCatId=9&prodFamilyId=2192
Deffinatly get a O ring chain. It keeps dirt out of the chain's rollers and pins.
Gold RK GB520EXW chain. Strongest Tensile strenght and better o rings than an X ring chain. It also comes with a clip style master link. That is what you use to conect the ends of the chain together.
http://www.rockymountainatvmc.com/productDetail.do?&navType=type&priceRange=allPrices&navTitle=Drive&webTypeId=36&webCatId=9&brandId=allBrands&prodFamilyId=3591
josh
josh
Thanks alot man.
