my left headlight quit working... i tested the bulb .. it's ok.. used a volt meter and i am not recieving any power,,, to the left side,, when i wired it up.. i set up for both lights to be on High Beam... can I just splice in to the right side light or will this be splitting power to 6 volts??? they are 35 watt 12 volt trail techs that are stock mount,,,, please help..... :shootself:
Did you test or check out the wires going to it too maybe one broke and you just didn't see it yet? Also check to see if theres a messed up wire going to the voltage regulator also.
pain in my ass... can i splice into the other light???????
I wouldn't mess around like that. Start testing the wires and make sure you regulator is fine . TEST TEST TEST :lol:
Its only simple wiring man. Grab your self a cheap $15 multimeter and have at it.
cut the regulator out and they get a whole lot brighter!!! ( for just a second then they blow up..)
try pluging it back in..
