ok hopfully someone can help me out here. cuz i am quite lost. here is what i did i replaced the gas tank on my 98 banshee now the kill switch worked before i look off the old tank but now since i put on the new one it dont. i looked to see if any wires had pbeen broken or pinched but nothing. can someone help me out before in lose my mind the rest of the way?????
is it just a factory on/off kill switch?
obviously the gas tank has nothing to do with it. you need to make sure nothing came apart and that there are no bare wires touching. it sounds like one of your plugs came undone.
If it just will not start and you have the torrs crap hooked up make sure you didnt kink the throttle cables making the slides stick open and the torrs kill the ignition
yes it is a factory kill switch and yes i can start it but i can not shut it off i have to choke it out. when i looked everything was connected and nothing was broken or out of place. would you think it could br thr switch its self?????
This sounds like it might just be a coincidence. Reminds me of back in the day when I worked for a Ford dealer. We called them "ever since" customers. "Ever since you rotated my tires, I don't get my favorite radio station anymore". I would agree with most people here. Something probably got un plugged. Likely if something was pinched and is grounded now, it wouldn't start at all. Atleast you've got that going for you! :headbang:
well i got the kill swtich fixed i opened up where the switch its self is and one of the wires came unsodered so solved the problem but a new one i have been baffled by is my set screw on my clutch basket seems to keep coming lose i am unsure of how to keep it from coming lose.... ANY IDEAS??????
Make sure to have it set correct, then use the nut and keep it tight with BLUE lock tight also Monster.gif
sounds good ill give it a try now one more question can i take the set screw completely out or will the screw shit up... cuz ill put lock tight all over the whole damn thing getting sick of playing games with it????
Yeah, you can, but when you put it all back together make sure to adjust it properly so the clutch with engage and disengage properly. Check all that before you put the cover back on so it works properly. You can fine adjust that up and the clutch lever adjuster also bro. But get the adjust on the pressure plate good and set first. :cheers:
