emerson750
Everything posted by emerson750
  1. Did you put the choke hose back in-between the carbs?
  2. I have a hose and the check valve works(rattles)
  3. Everytime I ride for longer periods. of time I get fluid (gas) bubbles coming up from the gas cap vent line any ideas? motor is prettymuch stock. .80 over, dg exhaust, pingle dual petcock,boysen radd reeds,no lid,k&n-proflow single, 300 mains,27.5 pilots. riding in midwest Illinois.
  4. pm sent
  5. Everytime I ride I get gas or gas vapor bubbling up out the ventline anyone have this problem?
  6. I went out to little sahara the 14-18 and on my last day I was entering the park and noticed that it was pueking oil out the vent line - question will it puke it out if i just overfilled it or did a seal let loose? will do a leak down test later forsure
  7. great! thanks for the help clymers doesnt help for things like that.
  8. ok so when i was changing jets i noticed that the left carb has a brass tube comming out the bottom of the carb and the right only has the one attached to the bowl ... so is the right supposed to have one too?
  9. If it just will not start and you have the torrs crap hooked up make sure you didnt kink the throttle cables making the slides stick open and the torrs kill the ignition
  10. I recently bought a banshee that needed a new topend. I rebuilt it and now am ready to fire it up. it is bored .80 over , has dg pipes , boysen radd valves & reed spacers, k&n filter with adapter. the mains are 290 , 25 pilots the lid is on with snorkel and 2x4 hole cut in lid Im at 603ft in Illinois and would like to run with the lid off so my question is where should I start . Thanks Anthony
