bbcmudtruck Posted March 22, 2010 Report Posted March 22, 2010 Has anyone ever tried this stuff? http://cgi.ebay.com/JANVIL-Plastic-Restore-Polish-Cleaner-Renews-Plastics_W0QQitemZ330415906404QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item4cee529e64 Quote
-Herbie- Posted March 22, 2010 Report Posted March 22, 2010 haven't tried that stuff but am starting to sand and refinish my plastic this week from instructions i saw on 3wheelerworld.com, should be interesting Quote
SAVAGE420 Posted March 22, 2010 Report Posted March 22, 2010 Hell for $9 whats there to lose. But if there deep scratches your still going to have to do couple steps and sand them some. Quote
SD1026 Posted March 23, 2010 Report Posted March 23, 2010 haven't tried that stuff but am starting to sand and refinish my plastic this week from instructions i saw on 3wheelerworld.com, should be interesting herbie you have the link? Quote
-Herbie- Posted March 23, 2010 Report Posted March 23, 2010 herbie you have the link? http://www.3wheelerworld.com/showthread.php?24247-Sanding-restoring-plastic.-How-to-guide Quote
DallasGDub Posted March 23, 2010 Report Posted March 23, 2010 That stuff works. you may have to sand some first. I took the suggestion from PaulieB over on E2S. He does some great work. I did mine. I had no scratches, just fading so no sanding for me. I did not think it would work. I took some 0000 steel wool, smothed it all out. I then used Orange Glo floor finish. Put it on in several even coats, and it worked. Shined up good. I need to redo it b/c it has some runs in it. I thought it was not working, so I picked it up a few times to look at it and it ran some. Hre is the link. http://www.blasterforum.com/do-yourself-20/how-restore-plastic-3274/ Quote
bansheesandrider Posted March 25, 2010 Report Posted March 25, 2010 I have used Mop & Glo to restore the shine. Quote
SD1026 Posted March 25, 2010 Report Posted March 25, 2010 Plastic Renew also works great. yea i saw this product on the internet. its for cars right. it comes in cans and gal form right. a lil expensive Quote
fastbanshee8 Posted March 25, 2010 Report Posted March 25, 2010 Do not use Plastic Renew. The first time you spill any kind of petroleum products on the plastics treated with it, or get any kind of grease, or oil removers on it, the crap will dissolve, or peel right off. Quote
bbcmudtruck Posted March 25, 2010 Author Report Posted March 25, 2010 Well I bought the meguirs headlight restore kit that comes with the buffing pad. I'm having so/so success with it so far. I will post up a pic this weekend after I get one side of the rears done. Quote
esterelbanshee Posted March 27, 2010 Report Posted March 27, 2010 I've been buffing the headlights of cars for years with great success. I also have a 3" orbital air powered high speed buffer which works plastic like a dream. Take your time and dont burn or melt anything Quote
bbcmudtruck Posted March 27, 2010 Author Report Posted March 27, 2010 What polish are you using and what pads on the buffer? I'm using a die grinder with a cotton polishing pad. It leaves the plastic cloudy in some spots and looks great in other areas. What am I doing wrong? Quote
SD1026 Posted March 29, 2010 Report Posted March 29, 2010 What polish are you using and what pads on the buffer? I'm using a die grinder with a cotton polishing pad. It leaves the plastic cloudy in some spots and looks great in other areas. What am I doing wrong? lambs wool pad. i am gonna try to use the same process as polisshing a new car. wetsand,red compound then white then some wax or glaze i will take pics Quote
HighFlyer Posted April 3, 2010 Report Posted April 3, 2010 I've sprayed Mop & Glo with my paint spray gun with great succes. Turn down the flow and apply light coats let dry between them. You get a good build up with no runs Worked great. Quote
