Additional pictures available upon request. All prices include shipping and insurance.
10mil Big Block Twister $2300
-Rotax powervalves
-Vforce 3
-Upp intakes
-25cc Domes
-76mm bore
-New O-Ring kit
10mil 125rod Twister Crank $700
-TZ bearing
2-5 Override $325
-Cut by WCR
Straight-Cut gears $275
-2.76 ratio
22x12x10 12-paddle SLS Haulers $375
-Douglas .125 rims
Cases $300
-Bored to fit big bore cylinders
-Trenched for 10mil crank w/ 125 rods
-Port-matched to Cylinders listed above
-All work done by Cascade Innovations
38mm Mikuni Flatslides (Alky) $450
-Billet Bowls
-Dave Moore Superjets
-Set up by Cascade Innovations
Shearer Hand-Coned OOF Pipes $450
-Out clutch side
-chrome
-flanges for silencers
-Big Flange
Twister Cylinders
Twister 10mil crank
2-5 Override
Straight-Cuts
Carbs
ho much for just the reeds ? i really need me some vf3s
These will not fit stock banshee cylinders. I will only sell them with this top end.
Thanks
- Jared
do you have a billet clutch basket?
I do, but its used. The anodizing on the basket is worn through. If you're still interested PM me and I'll give you a good deal on it.
- Jared
Thanks
- Jared
they would be for a 4 mill cub cylinder. thats cool good luck with the sell ! some nice parts you have here !
Cub cylinders use the same reeds and intakes as stock cylinders. These vforce reeds would not fit either one. They are much larger than stock reed setups.
Thanks
- Jared
because they cannot fucking read!!!
i'm guessing that this is /was the motor that was in the blue bike you have been trying to sell for long time?
if i had the money i'd buy it all from you to play with unless you might be interested in a 4 mill 480cc power valved cheeta?
Sent you a PM...
