Well long story short, I bought this banshee about 2 months ago. I have been riding it every couple days just about 15 minutes or so each time. When I first bought it, it was not leaking at all. It seems the longer it sits then it will start leaking gas/oil. Just the other day it started spitting gas/oil out the exhaust, and it seemed to smoke a lot more. Also I noticed one side and more exhaust pressure comming out than the other. I have alot of time on my hands so I thought what the hell and tore down the top end. Every thing looks good to me, but what do I know this is my first time doing this. I have a few pictures of some things but they are crappy pictures sorry.
The cylinders look real good to me, there is no deep scratching or anything. I tried to get a picture but it turned out to bad to see anything.
I took the carbs off and they just seem messed up. They are missing all of the screws it looks like to me. I left all the tubing on, Yes they are really cruddy, I haven't cleaned them up yet. Only tubing on them was the vent hoses and one tube connecting both of them. Would a bad needle cause gas to leak in when it is sitting in my garage if the gas is left on?
I guess what I am getting at is what should I do. I would like to keep it a cheap fix. I suppose I could of started slower, and changed out the plugs, checked compression, and rebuilt the carbs maybe, but wheres the fun in that. Should I do a complete rebuild or just buy a gasket set and put it back together.If you want any more pictures for clarification let me know.
It sounds to me like your problem was the carbs were leaking fuel into the cylinders when the bike was not running. It could be a bad float needle/seat, the o ring on the outside of the seat that seals the seat to the carb body could be bad, or the float level could be too high.I don't know what to tell you about putting it back together- if you are flush, you could get it bored and even ported, depending on what other mods you have, while it is apart. If money is tight you could just buy gaskets and put it back together, but I would at least run a glazebreaker through the cylinders and put new rings in it. I also woulnd not port it if you at don't at least have pipes, and you should have a cut head and possibly reeds. AND DEFINETLY CLEAN AND REPAIR YOUR CARBS.
One more question before I get this thing back together. Are the rings supposed to be pinching that little pin in the groove? I have them lined up but they aren't tight against the little pin, and they seem to be pretty loose around the piston not sure how they are supposed to be. I think I still have the stock piston, they have a G and an arrow pointing forward with the number 25 on them.
