How much oil does 99 shee take im hearing a whole lotta diffrent stuff.
I recommend you use the good synthetic 10w-30 tranny oil. This will prevent your clutch from slipping and help all the internals keep cool.
ATF type F all the way, i don't run it because it is cheap, i run it because it works EXCELLENT, it has grabbing agents in it to keep your clutches from slipping, and does not rob horespower. B)
Any tranny oil meant for a two stroke transmission has the same friction modifiers for the clutch that ATF has, and most of them have a better EP( extreme pressure) additive package to protect the gears, shift forks and bearings than ATF has. I prefer to use Klotz Flex Drive 30, part #KL506 in my tranny. My bike shifts the best with this and there is no wear on any parts the last time I split the cases.
