klever209
Everything posted by klever209
I'm trying to install the rigid industries universal atv mount. IN doing so I found out that the bracket hits the bars. I need to add washers between the clamps and bracket to raise it a bit and longer bolts. Anyone know what grade bolts I need? Or will any big box store hardware work? Am I doing this right? I don't have much experience messing with the bar clamps. Everything looks to be all stock on the shee. If anyone knows of a better way, please feel free to chime in also. The bracket has a .75" structural bend to keep it straight that I'd rather not cut unless absolutely necessary.
@JT correct. Strm Trpr recommendations are +7 (+ or - 1 degree). From some quick research looks like 5-6 is a well rounded number.
Thumbs up on the info @strm Trpr Back at it tomorrow morning. Will let you know how it turns out. Prog so far: https://www.dropbox.com/s/7hroqjn74zxj45w/IMG_9944.JPG?dl=0 https://www.dropbox.com/s/1ckalx0y5i4gvx2/IMG_0001.JPG?dl=0 https://www.dropbox.com/s/nm6d2bg3cofc7vx/IMG_9999.JPG?dl=0
I just received their FR lt +2+1 (original style I guess). Roger did mention he's looking into an alternative to the bomb proof ball joint mounts as a cost alternative though. Not exactly sure what that means and information was provided without solicitation for what it's worth. Their fab and materials used are bad ass. Started to mount them last night. What a bitch without the fork spreader bar. Did one side. Elkas arriving next week. Having trouble figuring out which top arm is left or right though
I always put a lock on the rear brake rotor and pull the seat off. With both wheels locked up it makes it difficult for people to simply push it anywhere. They'd need a few to carry it onto something or drag it somewhere. Also park it parallel and very close to your trailer. I always keep a rope near our trailer door. Wouldn't mind roping a thief around the neck and dragging his ass a few yards, in self defense of course.
Thanks guys. Ran without it over the weekend at Pismo and all went well. Matt, you still make those battery boxes?
Can I run quad safely without reservoir? I rigged a battery tray to run HID lights at night and cant make a bracket in time for the rez to fit both......? Need your thoughts guys.
Hey Snop, where can I find snowmobile reg/rec? My friend would like me to convert his Shee so I need another one. Also I've noticed you make some sick battery trays, do you sell them?
Vforce 3 reed valve install questions.
klever209 replied to Chuckie02Shee's topic in Banshee Repairs and Mods
I have them as well and the response is noticeable. -
I've never heard of this...how do you go about doing it?
4mm serval vs 4mm stock cylinder?
klever209 replied to wideopeninpa's topic in Banshee Repairs and Mods
Jeff, how much would it cost me to send you my stoke stroke motor and you +4 it and serval top end. I have cool head, don't know domes, stock carbs, 2-1plate KN filter, vforce 3 reeds and toomeys t5. Do you strongly recommend any upgrade/replacement of said parts. I also have HD clutch with pancake and timing plate. -
After you do, please post his response. I am also interested in the Serval. -
At the very least, you should do a good bleed down, after getting new hoses. My stock brakes work fine. I could never compare them to my CR250 but they will lock up and you will go over. The hoses get some of the spongy feeling out of the system with a shorter stroke, not that big but noticeable. Good luck.
Take it apart again and make sure it's not welded and it's adjusted properly. I had a similar issue except my clutch would not engage because the stock adjuster got stripped.
Take it apart at the clutch. I did my bike a year or two ago and it was pretty simple. I thought my tranny had gone out because it wouldn't shift and had weird cluth pressure. When I pulled the cover and all the stuff out I found the little center clutch adjuster had welded it self together. I bought a pancake style new instead to replace and made sure the ball and rod were not damaged, closed her up and been beating her to the ground ever since.
what to use to clean up cases before putting together
klever209 replied to chetgoff's topic in Banshee Repairs and Mods
I know brake cleaner gets off all the oils that prevent sealants from sticking good to surfaces. -
I converted got a small 5amp battery and bought two O'Reilly HID five inchers. The thing lights up our camp really nice at night. I wouldn't have done it another way.
Thanks guys.
What is clod seize?
What is the max hp one can expect from the stock carbs in a stock jug ported set up vs. a stroked.? The reason I ask is, I've been putting off the rebuild to save up for a stroker 4 m. Will I be able to benefit from stock carbs? Or do they hold you back. I ride in tight woods with many elevation changes and open dunes where i will drag race a few people as needed.
Anyone have parts i need that want to trade? My wife can't ride with the twist. She gunned it last weekend going up a dune at Pismo and performed a very creative but unrequested air leap off the face of the dune.
Hey guys, anyone know what it would take to go back to thumb throttle and about how much it would cost? I have already removed the TORS and have a CR style twist. Will I need many parts?
Thanks guys. I am leaving to Pismo Dunes tomorrow. I'm going to ride the $%it out of it and see what happens.
Thanks. Def not slipping.
