greenshee14 Posted February 24, 2010 Report Posted February 24, 2010 How much oil does 99 shee take im hearing a whole lotta diffrent stuff. Quote
TwistedSheeRida Posted February 24, 2010 Report Posted February 24, 2010 if your just changing it 1.6 - 1.7 quarts. if your doing a rebuild 1.8 quarts. it has a dipstick and it says on the cover how much it takes just to let you know. Quote
klever209 Posted February 24, 2010 Report Posted February 24, 2010 How much oil does 99 shee take im hearing a whole lotta diffrent stuff. I recommend you use the good synthetic 10w-30 tranny oil. This will prevent your clutch from slipping and help all the internals keep cool. Quote
TwistedSheeRida Posted February 24, 2010 Report Posted February 24, 2010 yeah i run amsoil 10w40 synthetic in the tranny. I dont care what people say about how cheap atf is and to run that instead. I spent 20 bucks on tranny oil last year and it still looked mint when i took it out. Quote
firebanshee Posted February 25, 2010 Report Posted February 25, 2010 ATF type F all the way, i don't run it because it is cheap, i run it because it works EXCELLENT, it has grabbing agents in it to keep your clutches from slipping, and does not rob horespower. Quote
bansheesandrider Posted February 25, 2010 Report Posted February 25, 2010 ATF type F all the way, i don't run it because it is cheap, i run it because it works EXCELLENT, it has grabbing agents in it to keep your clutches from slipping, and does not rob horespower. Any tranny oil meant for a two stroke transmission has the same friction modifiers for the clutch that ATF has, and most of them have a better EP( extreme pressure) additive package to protect the gears, shift forks and bearings than ATF has. I prefer to use Klotz Flex Drive 30, part #KL506 in my tranny. My bike shifts the best with this and there is no wear on any parts the last time I split the cases. Quote
