Why switch pipes if your motor is set up for t-5s ?
If I use the T5 pipe, I will not be able to mount the power valve housing on the left hand cylinder. The pipe / cylinder clearance is not enought to boult the housing.
The T5 pipe can only be monted if I intent to jam the power valve at the open fully open position.
