BigMatt Posted February 11, 2010 Report Posted February 11, 2010 Sometimes when ridding i get to 3rd and go to shift up to 4th it wont engage than other times it does, whats up it is only in 4th. Quote
firebanshee Posted February 11, 2010 Report Posted February 11, 2010 You might need a new shift shaft, the shaft that your shifter bolts to. I have had my bike start shifting bad and thought that i had tranny problems and found that it was just a bad shift shaft. On the end that contats the shift star pegs that double pawl and spring gets worn out. They cost about 35$ hopefully its not a internal trans or shift fork problem. Quote
sandman81 Posted February 11, 2010 Report Posted February 11, 2010 Sometimes when ridding i get to 3rd and go to shift up to 4th it wont engage than other times it does, whats up it is only in 4th. Mine did the same thing, my shift shft was out of adjustment because the adjustment bolt was lose( yellow arrow) Where the red arrows are pointing, make sure the space is equal on both sides and you adjust it by turning the bolt were the yellow arrow is pointing. Quote
BigMatt Posted February 11, 2010 Author Report Posted February 11, 2010 hey thanks alot guys i hope thats all it is so far thats what every one has told me, Shift Shaft, I'll take a look. sounds like thats it only because its not doing it all the time & its only 4th so far! Mine did the same thing, my shift shft was out of adjustment because the adjustment bolt was lose( yellow arrow) Where the red arrows are pointing, make sure the space is equal on both sides and you adjust it by turning the bolt were the yellow arrow is pointing. Quote
