Hey guys,
I just jetted the banshee, but it didn't quite go according to plan. Mods are: Toomey T5's, K&N Filter, K&N Powerlid and VForce 3 Rad Valves. I used 280 mains, standard pilots and Toomey needles on the 4th clip from the blunt end, as advised by a few members of the HQ.
When I fired it up I had to give it a touch of revs to get it to idle and while puffing a little smoke from the right pipe it shot a flame. I was a little worried, and my brother suggested unburnt fuel. No worries, so I kick it over again and the same thing happens. I've heard that the smoke could be a result of the carbs not being synced properly, but the flames from the right pipe have me very concerned.
At this point I had had enough fun for the night. Have you guys got any ideas as to where I've gone wrong? I'm meant to be going on a trip in two days so I need to get this sorted ASAP. Any help/advice would be greatly appreciated!!
Cheers,
Mike
TORS is still in place (ie. no TORS kit)
To the best of my ability, but I don't have the tool (will need to get one and do it)
I'm running the standard banshee pilots. The only thing I touched was the main jets, the needles and the air screws.
Elevation is roughly 6m above sea level (so basically sea level).
Temp is roughly 25-35 degrees celsius
Plugs are maybe a month old.
Choke tube and everything has been connected.
I hope something there helps. And sorry for the metric measurements.
Edited by MIKE_XT
Do you still have the stock needles?
Do you have 27.5 pilots
If it was me. I would put the 27.5 pilots in. Pull the power lid. Put the 280s back in. Turn the air screw 1-1/2 turns from fully closed. Make sure the carbs are really clean. But I also think that your mains might be running lean with the temps being cold and all. But remember when Jetting. Set the main first. Then the needle, then the pilot-air screw.
You should be close with that jetting.If anything i would say go one step up on the pilot. But i wouldnt think a stock pilot would be that far off. I ran t5's with clamp on KnN's with stock pilots and 280 mains,needle in the middle,and it ran great
