Shee1234 Posted February 6, 2010 Report Posted February 6, 2010 While changing coolant I pulled of the reservoir with out paying attention to hose locations. Should the hose running from the top of the radiator go on the bottom of the reservoir and the breather/vent hose on the top? Thanks Quote
jbooker82 Posted February 6, 2010 Report Posted February 6, 2010 Yep the bottom of the coolant tank goes to the top of the radiator up by the filler neck. The top hose on the rez tank is just a vent. You can put a stub pice of hose on and have it drain down. Quote
