BOOZER2009 Posted January 24, 2010 Report Posted January 24, 2010 Just changed from 25/260 to 30/290. the clip was in 4th notch previous to new jets. Should I leave it in 4th notch or take it to the third notch. If I understand correctly. My larger hets with it at the 4th notch would make it run way richer. Thanks FYI:FMF fatty w/ turnibe2 exhaust with K&n pods Quote
LiftdT4R Posted January 24, 2010 Report Posted January 24, 2010 Stock carbs? I was never a big fan of moving the clip on stockers, I always kept it on the middle notch, 3rd, and adjusted the jets accordingly. If you search around almost everyone is on the middle notch, so you should be able to find jetting specs for your bike that are really close. Or else post up your setup and someone can help you out. Quote
GrMeyer Posted January 26, 2010 Report Posted January 26, 2010 What is your elevation? If your in the 3k or higher. You should be fine with the 25 pilots. The 30s are way to big. I have 27.5's with a dune porting. As for the needle. You need to set the mains first. Then the needle. Then the pilots. And then the air screw. With the coldness. Your jetting should be in the 310 range. Start the needle on the middle clip. And put the stock pilots back in. Turn then 1-1/2 turns from seat. Also, read up on this site. It will help you out on whats going on with your carbs. http://www.dfn.com/benkaren/jetfaq.html Also list all the mods as well. But the big factor is do you have porting done? Quote
