VegasJeff Posted January 19, 2010 Report Posted January 19, 2010 Pro Design domes. Domes are recessed for a 4mm crank (eliminates the need for a spacer plate). One Dome has a couple small pits. $30.00 shipped. Quote
AKheathen Posted January 20, 2010 Report Posted January 20, 2010 umm, not to be the bearer of bad news, and mabey it's the pics, but it really looks like whoever "recessed" those domes fucked up and cut the inner ring off, rather than move the squish. i don't think they are even useable anymore. not the fist tome i've seen this happen. Quote
Gman-7m Posted January 20, 2010 Report Posted January 20, 2010 Pro Design domes. Domes are recessed for a 4mm crank (eliminates the need for a spacer plate). One Dome has a couple small pits. $30.00 shipped. Jef, big bore and "O" ring on the out side, or small bore and the oring groove machined off, also what is the depth for piston clearance, dome cc's, and squish angle?. Quote
BigRed350x Posted January 20, 2010 Report Posted January 20, 2010 No, that's a normal dome. I've got all kinds of domes and they come like that sometimes. They will hold the o-ring. They don't need a groove to hold the o-ring. Quote
AKheathen Posted January 20, 2010 Report Posted January 20, 2010 ok, i see it now. couldn't really tell from the angle/lighting Quote
Gman-7m Posted January 20, 2010 Report Posted January 20, 2010 Pro Design domes. Domes are recessed for a 4mm crank (eliminates the need for a spacer plate). One Dome has a couple small pits. $30.00 shipped. Jeff, I'll take them, where can I pick them up. Quote
VegasJeff Posted January 20, 2010 Author Report Posted January 20, 2010 Jeff, I'll take them, where can I pick them up. sold,thanks G-man! Quote
