make sure your carbs are in sync,float heights the same, idle screws are the same w/o tors switch,2 turns out on air screws,check compression,could also be right side crankshaft seal going bad. really need too know more about your mods if any.good idea to check your trans oil level.sounds more like carb problem though.
As the above poster said, it is most likely a carb synch issue, or they could just be dirty. Also, ameks ure the carb bowls aren't swapped side to side, they are unique. The one on the side with the choke knob will have a tiny brass jet at the bottom. This will also cause this problem.
