broncbob Posted January 18, 2010 Report Posted January 18, 2010 (edited) I'm looking to build a 4 mill dune/hill shooter quad. I'm thinking of having Herr do the porting and supply the parts for the 4 mill. I'll be using a Chariot timing plate, Chariot reed cages and intake, Noss cool head, Mikuni TM 32's and T5's Edited January 18, 2010 by broncbob Quote
jbooker82 Posted January 18, 2010 Report Posted January 18, 2010 It would run pretty good. Dune ported 4 mill is a fun ride. If you had a buddy that had cpi inframes you could try them out to see if you like how they ride. A dune ported 4 mill will run good on t5's too. Quote
sleeper06 Posted January 18, 2010 Report Posted January 18, 2010 I just finished putting together a 4milplayport for a two people.Fast racing play/duneport stays with my friends stock port cub out of the hole through 3rd gear,35mm carbs,shearers,155psi on pump gas.Fun bikes to ride Quote
