Crazyatvspazz Posted December 30, 2009 Author Report Posted December 30, 2009 I have t6 pipes on the banshee I have now and I had another banshee a while back that had fmf sst pipes. They were fairly close as far as power goes but the toomeys look better and sound 10 times better in my opinion. To run the t6 pipes you don't have to remove the coolant resevoir or use the airbox vents, they are so little I didn't even bother using them. Since you have the silencers for the fmfs I would just try to get some used sst pipes somewhere, I don't think you will be disapointed because they were a good all around pipe. thanks for input. think im going to get the sst's. Quote
volcrano Posted December 30, 2009 Report Posted December 30, 2009 thanks for input. think im going to get the sst's. putting the timing on +4 will decrease top end pu;; slightly.u might want to leave her at 0.just a thought. Quote
Crazyatvspazz Posted December 31, 2009 Author Report Posted December 31, 2009 putting the timing on +4 will decrease top end pu;; slightly.u might want to leave her at 0.just a thought. i dt wanna sound like an ass but isnt it the point of buying an adjustable timing plate so... you canadjust it lol? if i dont like it i can always change it back. Quote
georgie Posted December 31, 2009 Report Posted December 31, 2009 thanks for input. think im going to get the sst's. If you set up your bike for a strong low end to mid, their pretty good. I have them on my 358cc cub motor with a 2 into 1 set up carb. Quote
volcrano Posted December 31, 2009 Report Posted December 31, 2009 i dt wanna sound like an ass but isnt it the point of buying an adjustable timing plate so... you canadjust it lol? if i dont like it i can always change it back. um-yeah if it helps ur cause.u want top end-it will hurt that.if u like adjusting shit buy some lrds. Quote
Crazyatvspazz Posted December 31, 2009 Author Report Posted December 31, 2009 um-yeah if it helps ur cause.u want top end-it will hurt that.if u like adjusting shit buy some lrds. Well as it is now it has NO bottom end...like i originally said i want power every where. I figured the timing plate (which i just received from chariot...AWSOME!) would even out the bottom with the mid and top. if i sacrifice a small amount of top to have more bottom thats fine with me. Is my logic correct? also anybody have more opinions on jetting? thanks guys Quote
