Monster_M3 Posted December 15, 2009 Report Posted December 15, 2009 like the topic says, which of the two are more reliable and make more power? im trying 2 figure out which would be better on my shee stock bore ported 4 mill vs. stock crank ported cub 68mm cub cylinder Quote
T_Shee Posted December 15, 2009 Report Posted December 15, 2009 it depends on what kind of riding you are gonna do and what kind of porting. if you want more top end the cub would be better suited but if you wanna trail ride youd be better off with 4 mil and trail port. prolly do a 4 mil and porting for around the same price as cub top end. as for hp #'s im not sure Quote
Monster_M3 Posted December 15, 2009 Author Report Posted December 15, 2009 it depends on what kind of riding you are gonna do and what kind of porting. if you want more top end the cub would be better suited but if you wanna trail ride youd be better off with 4 mil and trail port. prolly do a 4 mil and porting for around the same price as cub top end. as for hp #'s im not sure i do drags and trails mainly. i was thinking dune/play port by HJR Quote
FASTOYS Posted December 15, 2009 Report Posted December 15, 2009 We have done full drag stock cyl 4mm and full drag Cubs. In a 100 yrds they are tit for tat and i wouldnt want to bet on either one they are so close. BUT after the that the Cub begins to outpull the stock cyls.. Both are reliable. If your saying drag and "TRAILS", then i think you will be much happier with a stock cyl play/dune port unless you have the extra money for cubs and dont mind the majority of the power to hit up top. Quote
jbooker82 Posted December 15, 2009 Report Posted December 15, 2009 A fast 4mill is a fun machine to ride. Mine has a super strong mid range hit and revs out really well. Quote
bbcmudtruck Posted December 15, 2009 Report Posted December 15, 2009 If you do more than 50% trail riding then you won't like a cub. A dune ported 4mil will be fast and have plenty of grunt for the trails. Keep in mind that you will need to complete the package which ever motor you decide to go with. ie clutch, pipes, carbs, reeds, head, possible override, etc. etc. Quote
FASTOYS Posted December 15, 2009 Report Posted December 15, 2009 If you do more than 50% trail riding then you won't like a cub. A dune ported 4mil will be fast and have plenty of grunt for the trails. Keep in mind that you will need to complete the package which ever motor you decide to go with. ie clutch, pipes, carbs, reeds, head, possible override, etc. etc. And in your case Ryan.....a damn swingarm! Quote
Monster_M3 Posted December 15, 2009 Author Report Posted December 15, 2009 If you do more than 50% trail riding then you won't like a cub. A dune ported 4mil will be fast and have plenty of grunt for the trails. Keep in mind that you will need to complete the package which ever motor you decide to go with. ie clutch, pipes, carbs, reeds, head, possible override, etc. etc. its like 75% drag 25% trails. my set-up is mainly for asphault racing but i want it be ridable for the trails since im selling my YFZ(MX, drag, and trails) i just wana be able to ride it through trails and not have no power OR have to hit powerband and slam into a tree im accustomed to my Ported YFZ and just wana do my banshee right so i dont get disapointed. im prity sure either set up will destroy my YFZ though LOL i know the to get the full potential out of either set-up i'll need all the things Ryan stated. im just saying all things equal which would be my best choice of the two? Quote
jbooker82 Posted December 16, 2009 Report Posted December 16, 2009 You could build a 4mill stock cylinder. Then if you need to up grade sell your top end and buy a 4mill cub top end. Quote
J-Madd Posted December 16, 2009 Report Posted December 16, 2009 You could build a 4mill stock cylinder. Then if you need to up grade sell your top end and buy a 4mill cub top end. Good idea I agree. Also, HP and 300 ft times are similar with a drag ported 4 mil and a stock stroke 68 mm cub (at least the ones that I've had.). The stock cylinder 4 mil should have a little more bottom end. Quote
jbooker82 Posted December 17, 2009 Report Posted December 17, 2009 Good idea I agree. Also, HP and 300 ft times are similar with a drag ported 4 mil and a stock stroke 68 mm cub (at least the ones that I've had.). The stock cylinder 4 mil should have a little more bottom end. Yea you can almost get your money back out of your stock cylinders if you get a Reputable builder's port job, and it is a running top end. That way it is no wait. Quote
