YFZMAN Posted December 12, 2009 Report Posted December 12, 2009 I have an 05 Banshee with T5 Toomeys and standard air box. I can't get the Banshhe to idle, the TORS are still connected, seems like I dont have much adjustment on the right carb. Pressure form the right exaust is much lower compared to the left. I'm going to check compression today. I installed new plugs and even swapped plug wires. Seems to point back to the right cylinder. Quote
YFZMAN Posted December 12, 2009 Author Report Posted December 12, 2009 Checked compression today left 118 right 80lbs New top end re-build? Quote
FrankieSquid Posted December 12, 2009 Report Posted December 12, 2009 Checked compression today left 118 right 80lbs New top end re-build? Very much so. There's your reason why on had more compression than the other. Quote
