drap660 Posted December 10, 2009 Report Posted December 10, 2009 I have a 4mill stock cyl 66mm, no overide, CPI, DF3's, 17cc domes 190 compression banshee that did 105 in the 1/4 with stock carbs and 110 shortly after the 1/4. I threw in a set of 35mm PWK and didnt see much improvement but did see my gas tank go to empty 10 times faster. I guess what I am asking is, are the big carbs really worth it???? I jetted the balls out of them and got them to be perfect (no bog, straight pull through each gear). I ended up with 45pilot 152main. I am running airbox with adapters. Gearing is 16/38. Any advice will be appreciated Quote
getonit Posted January 26, 2010 Report Posted January 26, 2010 did the carb's improve your time's would be the question. Quote
