TeamRags Posted December 2, 2009 Report Posted December 2, 2009 It's time to change out the current haulers that I have and I found a good deal on some tires that are 1 inch wider. I currently have 20x10x10 and the bike runs great and pulls pretty hard. Will a 20x11x10 make that much of a difference? Quote
BigRed350x Posted December 2, 2009 Report Posted December 2, 2009 It's time to change out the current haulers that I have and I found a good deal on some tires that are 1 inch wider. I currently have 20x10x10 and the bike runs great and pulls pretty hard. Will a 20x11x10 make that much of a difference? Its Height x Width x Rim Size. So the added inch on the width will just give you a little bit more of a balloon effect at high speeds. But on a 20" tire my bet would be that you won't even notice any difference at all between the two. - Jared Quote
patrickkomar Posted December 2, 2009 Report Posted December 2, 2009 I'm with big red here, most likely wont be able to tell. Do you mind me asking why you went with a 10" rim? Quote
TeamRags Posted December 3, 2009 Author Report Posted December 3, 2009 I'm with big red here, most likely wont be able to tell. Do you mind me asking why you went with a 10" rim? When I purchased my first set of paddles, the salesman told me that less sidewall had less give and the tires lasted longer? Didn't know the difference and have stayed with 10" ever since. Tell me this, Has anyone used Kenda/SkatTrak haulers? I hear they may be a bit heavier? Quote
