hauser2169 Posted November 28, 2009 Report Posted November 28, 2009 k so im doing a rebuild, cylinders and pistons should be back from jeff monday.. i was lookin over my motor and found a hoe right by the clutch arm.. what goes there, breather of some sort? i cant find it in my manual or a parts pic Quote
98_shee Posted November 28, 2009 Report Posted November 28, 2009 Are you talking about the one rite behind the left cylinder that runs straight down? If so its noting just a hole that runs all the way through. Quote
Screaming Yellow Zonker Posted November 28, 2009 Report Posted November 28, 2009 I thought the same thing the first time I saw that too. than I put a screw driver all the way through it and realized it was suppose to be there. Quote
AKheathen Posted November 28, 2009 Report Posted November 28, 2009 yah, just a drain hole....dropped a screw in there once.....as soon as i saw the hole, i nearly shit myself thinking a plug was missing and i'd have to split the cases... found it on the belly pan... Quote
