cousinsracing Posted November 23, 2009 Report Posted November 23, 2009 hey i have two K&N pod filters that are attached directly to my carbs (Keihin 35mm pwk's) i ride a lot of trails and want to get an airbox so i dont have to worry about sucking water into my motor. what is the best way to accomplish this? Quote
jahrastapark Posted November 23, 2009 Report Posted November 23, 2009 im in the same position. i run K&N pods, and need some protection against water. get an airbox off ebay for 30 bucks, and the single K&N filter. lotta poeple do deals on a whole setup. Quote
WantABanshee Posted November 23, 2009 Report Posted November 23, 2009 will the stock airbox mate up to the aftermarket carbs though?? Quote
GNR101 Posted November 23, 2009 Report Posted November 23, 2009 i mate my airbox fit my pwk33s ..same size as 35s .. just had to move the airbox back a little and make a little bracket.. nothing hard about it Quote
GNR101 Posted November 24, 2009 Report Posted November 24, 2009 im at work for another week.. so cant get pix yet.. but i should beable to get some when im back Quote
WantABanshee Posted November 24, 2009 Report Posted November 24, 2009 ^^ That'd be great thanks Quote
Drewski Posted November 25, 2009 Report Posted November 25, 2009 you can get an adapter from jeff at FAST so you can mate your big carbs to the stock box but it will be a tight fit Quote
Rollerstarter Posted November 26, 2009 Report Posted November 26, 2009 you can get an adapter from jeff at FAST so you can mate your big carbs to the stock box but it will be a tight fit two pwk 35 with stock airbox just need to cut a slice to te air box boots atachement and buy an upp bigger boots fit verry flush is hard to install and remove the carb Quote
