Rollerstarter
Everything posted by Rollerstarter
  1. two pwk 35 with stock airbox just need to cut a slice to te air box boots atachement and buy an upp bigger boots fit verry flush is hard to install and remove the carb
  2. im recently bought cub and i need to polish them so how to polish a cub materiel need and tips to find mirror finish on my cub
  3. im need help to port my exaust cylinder(trail port)tool and tip to make a good home made port for free money to get hp.my banshee on dynojet 47,6hp and 35,4lbs of torque and guy to dyno recomend me to port my exaust to get more horse power with my settup.(t5,v-force2,knn on airbox,knn extreme power lid,boost bootle,coolhead prodesign 20cc dome,piston wiseco prolite 66,50over,intake sligly ported transfer sligly ported,and crankase and gasket matching to cylindrer ,im run o pump gaz.
  4. i love ride on snow
  5. the 4snow rock solid on the snow im use only 4snow im live in quebec and ride all winter with this tire and work great.
  6. good or bad for winter im live on canada
  7. Where are you getting your information Rollerstarter? I would like to see this. Rmstator.inc is a 30km from my home and I am going to move this week to buy a ajustable timing plate.the guy made a demonstration and said that c finalized soon and that it will have between cost 450-500can for the complete kit with big stator plate and everything.
  8. the banshee tranny work perfectly on reverse same to foward the kit not need electric starter.
  9. for,is not a joke
  10. t5,v-force2,knn filter and knn extremme power lid,timing plate set to +4,cool head prodesign 20cc dome,boost bootle,wiseco prolite piston 66.50mm oversize,intake ported and transfert ported and crankcase match port(trail port),barnet clutch how the good carb for the setup
  11. rm stator inc work on new kit for banshee (reverse adon)the kit is coming and work just need finalising.rm stator guy show me the demo.the kit require no transmission modification only electrical.
  12. http://cgi.cafr.ebay.ca/30MM-D-slide-Carbs...1QQcmdZViewItem good or bad carb
  13. my banshee mod is:fmf fatty and powercore2,v-force2,boost bootle,knn airfilter and precharger,knn extremme power lid with precharger,coolhead prodesign with 20cc dome,barnet clutch,tors eliminator. best carb for my setup my banshee not ported and im run with pump gaz the carb friends my offert for verry low price 1:mikuni 28mm flatside 2:keinn pwk 33mm semi-flatside 3:or other idee carb setup
  14. my gasket on my cool head prodesign leak a little bit on 1 cylinder my prestone level always corect im not need to refil. any idee ton fix this problem or im need to buy new gasket set. my cool head is new and my head is torked at 20lbs.
