Toomey Banshee Posted November 20, 2009 Report Posted November 20, 2009 Doing my youngest sons '99 top end and some updates. Stock stroke with T-5's, cool head with 20's and VF2's. Parts list to date-pistons (weiscos), bore cylinders, new V-force 2 reed pedals, magnetic drain plug, advanced timing plate, lightend flywheel, case saver, e-z pull clutch and perch (already have a FAST clutch setup), e-brake block off, new O-ring kit for cool head, moded shift star, packing for the T-5's. Thats what I have for now. Its not gonna get ported, has stock carbs with pods and I'm not eliminating the TORS. Anything I'm missing? Quote
00sheerzr Posted November 20, 2009 Report Posted November 20, 2009 check all bearings and bushings, Quote
bansheesandrider Posted November 20, 2009 Report Posted November 20, 2009 Do away with the TORS System, you can getrid of it and keep the thumb throttle if you want. If you take the TORS off it is much easier to work on the carbs when you need to, and you won't have to worry about it causing problems down the road. Quote
AKheathen Posted November 20, 2009 Report Posted November 20, 2009 perhaps you should list all the mods.......of, coarse you are gonna want the reed and base gaskets......not sure why you would need the lightened flywheel. perhaps you may want to up the stator watts, update the impellar/gear. pankake bearing, in case he accidentally holds the clutch in too much....pto bearing. i would strongly suggest the tors removal, as it not only makes jetting 100x easier, but relieves alot of strain on the rubber intakes, which might need replacing. if you are getting your bore/hone locally, make sure it's bored to the pistons, and that there is still port chamfers.........oh, and don't forget the boost bottle Quote
Toomey Banshee Posted November 21, 2009 Author Report Posted November 21, 2009 perhaps you should list all the mods.......of, coarse you are gonna want the reed and base gaskets......not sure why you would need the lightened flywheel. perhaps you may want to up the stator watts, update the impellar/gear. pankake bearing, in case he accidentally holds the clutch in too much....pto bearing. i would strongly suggest the tors removal, as it not only makes jetting 100x easier, but relieves alot of strain on the rubber intakes, which might need replacing. if you are getting your bore/hone locally, make sure it's bored to the pistons, and that there is still port chamfers.........oh, and don't forget the boost bottle Thanks so far. Have the reed gaskets, forgot about the base gaskets. Good thought with the impellar, def. gonna add that. Gotta get a flywheel puller as well. As far as the TORS goes its been disconnected for years I actually like the thumb screws to help sync the carbs. Looking into porting my boost bottle unless someone has one available here thats been ported. Quote
jbooker82 Posted November 21, 2009 Report Posted November 21, 2009 I didn't see any wrist pin needle bearings. Quote
TwistedSheeRida Posted November 21, 2009 Report Posted November 21, 2009 make sure you have good break pads to stop that beast when your done building it lol Quote
