Hello all,
The Banshee was getting pretty sluggish on the bottom end, but winds out good still. Before putting in new plugs, did a compression check. Left bank is 135 and right bank is 150. Reading that possibly cracked or broken reeds could be the culprit, if that's the case, wouldn't it crap out on the top end too?
Any input appreciated.
Thanks, Terry
I should probably verify that I did the comp test correctly also. Only had the plug out of the cyl I was working on, throttle closed, filters on, and kick till the gauge topped out. Is that correct?
Thanks, will give that a try again tonight.
The reeds will not cause your change in compression. More than likely a piston/ring issue here.
Brandon
Mull Engineering
