4mil crank or 62mm cub
batshee
Hey guys am not sure on the route i should take.I mostly ride in paked construction like dirt fields,also do some street racing,along with a bit of trail riding i just want to have a good power range all around without having to do so much motor work such as streching cases and things of that nature.
so should i go with a ported cub or a 4mil stroker crank
thanks alot
Well by the sounds of where and what type of riding you do. I would do a 4mil stock cyl with a dune port. Good bang for your buck and not really expensive. Pretty good power from mid-top. ZA011179361033.gif
No such thing as a 62mm cub though. 68mm and up.
Thanks alot savage but what would i need for a 4mil can i get a list from one of you guys i got the following which i think its a good start
+8 swinger,cpi inframes,28mm keihns
Cubs are available in 65mm 66mm, and 68, supercub 72.
Really need to ask yourself if you want big topend power, or more of a broad not so peaky power curve. Also if money is a major factor stock cylinder porting will be a more viable option. Give me a call if you have any questions.
Andy
M&M
9182731700
Do you want to stick with gas or run alky?
stock stroke - trued welded crank
ported cases
cheetah cub cylinders 68mm
ported
r6 clutch
lockup
new clutch cover
sell the carbs you have
go with some 34's, billet bowls, pingel alky :)
yeah they make 65mm cheetah motors...... :jesterlaugh:
thats the smallest i believe.......
stellar performance makes awesome swingarms.... :headbang:
RDZ has what u want as far as cubs kits and good prices....
alky is more for race.... i think hes lookin for more of a fast dune/play bike <_<
But why when Andy from M&Matv above is a site sponsor and has GREAT prices and services. My 205876432cents.gif
I think a good ported 350 stock cyl will work great for your type of riding. They are still our most popular and dependable motor. There are plenty of site sponsors on here capable of helping your build including us!
