bkcustoms Posted October 7, 2009 Report Posted October 7, 2009 I was wondering if any of you experts could lend me some advise. I have alot of work done to my bike but it is not dialed in. It takes forever to get it to start, then it will smoke a little and it does not like to idel. I dose however run good when its running. Ok here is what mods it has: toomy t5 pipes, advanced timing, lightened fly wheel, 35mm carbs, v force reeds, cool head, chromoly racing crank( not a stroker) and a mild bore and stage 1 porting and polishing. Can anyone please tell me what jets i should have in the carbs, what domes should be in the head, and what the timming should be. I belive that those are the 3 main problems i am having it those componets are not setup correctly. Thanks for all your help kyle Quote
black sunshine Posted October 7, 2009 Report Posted October 7, 2009 What domes are in the coolhead? Those are giant carbs for your mods!! Quote
bkcustoms Posted October 8, 2009 Author Report Posted October 8, 2009 im not exactly sure what dome i have.Im going to be pulling it apart in the next week and i wanted to know what should be in there and if they were different then i would buy the right size and put them in. And i bought those carbs because thats what i was told i should get by a banshee performance place in so cal. Can i just jet the carbs down? Thanks so much for your help. Quote
RippinShee Posted October 8, 2009 Report Posted October 8, 2009 You should just keep those carbs, theyre really not that big for youre setup. Set the timing at +4 or +6 and see how it reacts. Start at 155 main and 50 pilots, with needle on middle clip. That will be rich. Work youre way down from there. Quote
