bkcustoms
bkcustoms's Achievements
  1. im not exactly sure what dome i have.Im going to be pulling it apart in the next week and i wanted to know what should be in there and if they were different then i would buy the right size and put them in. And i bought those carbs because thats what i was told i should get by a banshee performance place in so cal. Can i just jet the carbs down? Thanks so much for your help.
  2. if you go to the attached link http://www.mcmaster.com/#tubing/=3ygluh it is a place called mc master carr. If you select on single line tube and the select the clear for color they have some tubing that it rated up to 500 deg which should be enough. I hope this help you.
  3. I was wondering if any of you experts could lend me some advise. I have alot of work done to my bike but it is not dialed in. It takes forever to get it to start, then it will smoke a little and it does not like to idel. I dose however run good when its running. Ok here is what mods it has: toomy t5 pipes, advanced timing, lightened fly wheel, 35mm carbs, v force reeds, cool head, chromoly racing crank( not a stroker) and a mild bore and stage 1 porting and polishing. Can anyone please tell me what jets i should have in the carbs, what domes should be in the head, and what the timming should be. I belive that those are the 3 main problems i am having it those componets are not setup correctly. Thanks for all your help kyle
  4. If anyone can help me it would be great. I have a 1995 banshee and here are the mods that have been done, Advanced timming, lightened flywheel, minor bore, stage 1 porting and polishing, 35 mm kleen carbs, v force reed valves, chromoly racing crank (not a stroker), Cool head. I am having problem with it starting, it take forever to get it to start and when its running it runs good, smokes a little but it does not want to idel. Can someone please make a suggestion on the setup, im not exactly what jets or in the carbs and what size domes and in the head but it would be great if some one could tell me with all the mods that i have done what jets i should be running and what domes should be in the head and so on. Thanks so much for everyones help. Kyle
