RippinShee Posted October 5, 2009 Report Posted October 5, 2009 I bought a set of used Keihin PJ 34's and have had them installed in my bike for about a week now. I was syncing the carbs and noticed the slides look different. I pulled them out and left left one at the bottom, the taper is huge, like the big u at the bottom. The right side is much flatter. WTF? Quote
blowit Posted October 5, 2009 Report Posted October 5, 2009 (edited) I bought a set of used Keihin PJ 34's and have had them installed in my bike for about a week now. I was syncing the carbs and noticed the slides look different. I pulled them out and left left one at the bottom, the taper is huge, like the big u at the bottom. The right side is much flatter. WTF? Better get a hold of the seller because you have an issue there and the original owner likely knows about it. Yes, they should match. B EDIT: OK, I got it, the original owner drag ported only one cylinder and woods ported the other so he could have the best of both worlds..damn, where are my smileys when I need them... Edited October 5, 2009 by blowit Quote
Tedder Posted October 5, 2009 Report Posted October 5, 2009 (edited) Yep, They need to match. Hard to say if the seller knew about it or not. You'll probably only need to buy for one carb. Keihin link: http://www.keihin-us.com/slide.htm Sudco link: http://www.sudco.com/Diagrams323728/exppj.gif Edited October 5, 2009 by Tedder Quote
sleeper06 Posted October 6, 2009 Report Posted October 6, 2009 Same thing happened to me from this guy from NC,I was told they were35mm PWKs but I measured the ID of the carb throat and they were two diffrent carbs,needless to say I got screwed so watch out.He told me I was switching carbs out,for what I dont know!!! Quote
