temp
banshee-mike
a temp gauge plumbed into the rad hose that goes to the head, a infared temp gun will also work and is nice because you can check the heat differences between the cylinders and the exhaust pipes. Also they have stick on temp stickers that seem to work ok. Lastly you can get a mr gasket cap that goes on the rad that will give you an idea also.
http://img28.imageshack.us/img28/8130/sheetempguage004.jpg
http://img136.imageshack.us/img136/2346/sheetempguage003.jpg
http://img200.imageshack.us/img200/3750/sheetempguage005.jpg
Dont mine the dirty hoses :D
Works great for me. Some people had problems with the first gen ones. Ive had no problems with this second gen one. You have to run resistor plugs and run the single wire as far away from the coil and all other shee wiring as possible AND shield the wire with electrical shielding. The electrical noise for shees makes other shit mess up sometimes and reset. No problems with mine the way i had it.
Takes readings every 2-3 seconds. I like it alot. Yes i have it in the lower hose, i wanted to run it in the upper hose but there was not really enough room in front of the cooler. Ill put it up on the top hose this winter when i put the new hoses on. The gauge housing and inline probe housing is billet and the gauge is under a piece of removable lexan and is sealed in with and o-ring.
It runs off a lil watch batt so no need to splice into the harness.
Edited by savage420
maybe i missed it but where did you get that? Got a link?
The esr's are a nice gauge. I have their black one on my raptor. It might be hard to read on the banshee. You want to mount it in the top hose (front of the head to the top of the radiator.) You could mount it in that hose behind the gas tank shroud. That way you can read the gauge through one of the cut out holes.
