A03banshee Posted September 27, 2009 Report Posted September 27, 2009 Just wanted to get your guys opinion on what carbs i should buy. Carbs are for a 4 mil engine with an aggressive trail/mx port job, cool head with 20cc stroker domes (170 psi), +4 timing, and dmc 916 pipes. Bike is mostly used for trail riding with the occasional trips to the dunes. I want carbs that are going to give me a nice power improvement everywhere. Been looking at PWK's , but not sure what size would be best. Any help or suggestions would be great. Thanks Quote
sleeper06 Posted September 27, 2009 Report Posted September 27, 2009 I ran a trail 4mil set-up with 33pwk,the bike had crazy torque and low end but screamed on top when needed Quote
Sammy Posted September 27, 2009 Report Posted September 27, 2009 How about middle of the road. 30's Quote
jbooker82 Posted September 27, 2009 Report Posted September 27, 2009 I would run Keihin PWK33's. Quote
Snopczynski Posted September 27, 2009 Report Posted September 27, 2009 Mikuni TM 30's, I dont think I would go over a 32mm. Quote
donkeypuncher Posted September 28, 2009 Report Posted September 28, 2009 are the trails you ride tight/technical or wide open? if they're tight i wouldnt go with anything larger than a 30mm carb. if they're wide open then 33's or 35's will be what you're lookin for, i would lean more towards the 33's. Quote
