I have the coolant overflow behind the air box, where do the upper and lower hoses go? Also the line on the left side on top of radiator, wheres it go?? The "T" connector I know goes to vent under cover on right side of case and hooks to the vent on motor, but I can't find that vent line, maybe it is not on mine - is that not good? Where does the 3rd line go to on the "T"??? Thanks
Trish- not totally dumb just dont have my clymers!
the line comming from the top of the radiator under the radiator cap goes to the bottom of the overflow.
The rear gearbox vent goes to the T connector. Out of the T connection one line goes to right side under the waterpump cover, while the other pipe from the T goes along the frame by the right exhaust chamber and hangs to the ground.
The pipe from the top of the overflow bottle follows the other pipe down past the right exhaust chamber and to the ground as well. both of them are vents to relieve pressure
Edited by doorslammer
