Ok well recently started getting the banshee out of storage and running again. At first
I couldnt get it to start at all, and then after new the reeds, new sparkplugs, replaced the
header gaskets, and cleaned the carbs out it will start. But the right cylinder runs fine and
the left sputters, back fires constantly(left and right if you are sitting on the bike)
I checked and it is getting spark and getting fuel... Dont know what to check next...
You may have a clogged pilot jet in the left carb. You did reconnect the choke tube between the carbs, right?
being that you had the carbs apart, make sure they are synced up properly
swap the plug wires to see if the problem switches to the other side, if so, its the coil or wires
make sure the stator wires are not ate through anywhere, that will cause a miss on one cylinder.
well I spent alot of time going thru the carbs, and checking the jets and they were as clean as can be when reinstalled. and yes, the choke tube was on. Thanks for the ideas!
Well I have the airbox off and I can look straight into the carbs and the slide go up at the same time but they the right side goes up just a little higher than the left... Is this ok? With the plug wires, can i just switch them from plug to plug or do I need to try and switch it all together?
Now I will need some guidance from somebody on how to check the stator wires... but from what you say definitely sounds
like it should be checked. Thanks man!
nothing special, just pull the wires off and swap them on the plug tops, thats it, if the problem switches sides, you have your culprit, or at least a place to start looking
Ohh ok. Thanks man, thats what I figured but might as well check.
Now, how do I go about checking the stator wires and stator itself?
I bet you it's a fuel related issue IMO
Make sure you don't have any airleaks spray some carbcleaner around intake boots and what not while its running
To test stator and other electrical components you'll need a multimeter to test ohms
If you don't have a clymers manual already.. get one.
In the mean time heres a good electrical FAQ
http://www.dfn.com/benkaren/elecfaq.html
Edited by Idontknowwhy
Hey guys I really appreciate the advice but I did a combustion test and that left-side had wouldnt hold any pressure at all. So I decided to break it down.... Its not good!! HAHA the piston rings on the left side are basically gone!! So dont need anymore help right now unless you know of a shop near Houston, Tx that will do a good rebuild for me. Thanks again thought guys, Mel
